MMoexp: EA FC 25: A Guide to Elevating Your Game with New Sk
The latest version of EA's popular football series,
FC 25 Coins, brings a fresh set of skill moves designed to enhance gameplay. These exciting techniques allow players to showcase their flair and creativity on the virtual pitch. Let’s take a closer look at the four new skill moves you can master.
Big Feint (2 Stars)
The Big Feint is a clever trick that can confuse defenders. To execute this move, hold the L2/LT button and flick the right stick left or right, followed by an optional exit in any direction using the left stick. This maneuver lets you quickly change direction and shift the ball, creating space for passes or shots.
Tips for Mastery: Focus on timing and precision. Practice the Big Feint in various scenarios, like receiving the ball or while dribbling. Experiment with different exit directions to keep defenders guessing and find what works best for your style.
Stop and Go (2 Stars)
The Stop and Go is a straightforward yet effective skill that can catch opponents off guard. To perform it, hold the L2/LT button, then move the right stick back and forward. This move allows you to halt the ball suddenly and then accelerate, creating space and leaving defenders behind.
Usage: This skill is particularly useful in tight situations or when you need to shift the pace of your attack. It’s great for turning quickly when receiving the ball with your back to the goal. Remember, this move is cancelable, so you can smoothly transition into another action if needed.
Step Over Ball (4 Stars)
The Step Over Ball is a flashy skill that can leave defenders bewildered. To perform it, hold the L1/LB button, flick the right stick forward, then move it left or right. This technique involves stepping over the ball before rolling it in your chosen direction.
Advantages: The Step Over Ball is excellent for one-on-one situations, especially if you have a good dribbler. Its cancelable nature allows for quick direction changes or passing if the opportunity arises. Keep in mind that this move requires 4-star skill proficiency, making it more challenging than the previous moves.
Toe Drag Stepover (5 Stars)
The Toe Drag Stepover is the most complex of the new skill moves, needing a 5-star rating to execute. To perform it, hold the L1/LB button and spin the right stick either right, back, and left or left, back, and right. This intricate maneuver drags the ball with your toe before executing a stepover.
Mastery Tips: The Toe Drag Stepover is flashy and can leave defenders in the dust, but it demands precise timing and control. It’s best suited for skilled dribblers who can capitalize on the space created. While it may take time to master, executing this move effectively can be a game-changer, allowing for dazzling plays and scoring chances.In order to let you go further in this new football world, MMOexp provides a convenient way -
cheap EAFC 25 Coins to help you improve your game progress and unlock more exciting content!
